Hello everyone,
I am trying to get the union family set for ducts and pipes in routing preferences for revit 2022. I managed to get the one for duct types but the same method fails for pipe types. You can see that python recognises that PipeTye has a attribute called “Union” but it is set to none eventhough I made sure that it is set in revit. Any advices?
@tarek.mallak It is working perfectly from my side, can you share your script?
try using RoutingPreferenceManager
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Plumbing import *
pipe = UnwrapElement(IN[0])
manager = pipe.PipeType.RoutingPreferenceManager
ruleUnion = manager.GetRule(RoutingPreferenceRuleGroupType.Unions , 0)
unionType1 = doc.GetElement(ruleUnion.MEPPartId)
OUT = unionType1
Works perfectly! Thanks a lot!
