Getting Routing Preference Fittings Information
Hi, can we get access to Routing Preference family Types for Junctions, Unions etc for MEP Duct/Pipe types?
Hello
you can use the API
https://www.revitapidocs.com/2020.1/9fd171c5-b908-07d0-6fdc-bbcdcfae35a4.htm
an example
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
element = UnwrapElement(IN[0])
out = []
elemType = doc.GetElement(element.GetTypeId())
dictPrefEnum = dict(zip(System.Enum.GetNames(RoutingPreferenceRuleGroupType), System.Enum.GetValues(RoutingPreferenceRuleGroupType)))
routManager = elemType.RoutingPreferenceManager
for name, enumVal in dictPrefEnum.items():
	ruleCount = routManager.GetNumberOfRules(enumVal)
	temp = []
	for i in range(ruleCount):
		routeRule = routManager.GetRule(enumVal, i )
		mepId = doc.GetElement(routeRule.MEPPartId)
		temp.append(mepId)
	if temp:
		out.append([name, temp])
OUT =  out
Hi, Thank you for your reply. It looks like working for Elements. I’m trying to make it work for list input and added “final_out” variable. Will you please help what am I doing wrong? I’m just starting to learn Python.
Hello @Sujan
try this
import sys
import System
#import Revit API
toList = lambda x : x if hasattr(x, '__iter__') else [x]
elements = toList(UnwrapElement(IN[0]))
result = []
for element in elements:
	lstPreference = []
		temp = []
			temp.append(mepId)
		if temp:
			lstPreference.append([name, temp])
	result.append(lstPreference)
OUT =  result
Hi! Good thing I found this thread. I’m trying to Set different kind of elbows automatically based on some criterias other than diâmeter than connecting the pipes, could I Set the preffered type through RoutingPreferenceManager?
