Pipe to topo
I’ve done MARCELLO SGAMBELLURI, s “Make MEP Pipe System Families in Revit follow Topo with dynamo”. Where can I find he is using “Pipe.CreatePipe” node.
DATASET was not included.
You need something like this.
Import ToDSType(bool) extension method
Import geometry conversion extension methods
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
FirstPoint = IN[0]
SecondPoint = IN[1]
pipeType = UnwrapElement(IN[2])
systemType = UnwrapElement(IN[3])
level = UnwrapElement(IN[4])
levelId = level.Id
elements = []
Start Transaction
for i,x in enumerate(FirstPoint):
n = i % len(systemType)
pipe = Autodesk.Revit.DB.Plumbing.Pipe.Create(doc, systemType[n].Id, pipeType.Id, levelId, FirstPoint[i].ToXyz(), SecondPoint[i].ToXyz())
elements.append(pipe.Id)
OUT = elements
Don’t know how to paste code :smiley:
@Tomasz_Puchala Highlight the code and press </>
Import RevitAPI
clr.AddReference("RevitAPI")
FirstPoint = IN[0]
SecondPoint = IN[1]
levelId = level.Id
elements = []
Start Transaction
OUT = elements
Hehe, thanks!
# Import geometry conversion extension methods
# Import RevitAPI
FirstPoint = IN[0]
SecondPoint = IN[1]
levelId = level.Id
elements = []
# Start Transaction
OUT = elements
I made a script but I did not get to work.
The included files
Regards ek
Pipe_Line_3D.rvt (2.9 MB)
Pipe_Line_3D.dyn (18.1 KB)
