[MEP] Create pipe with line - Python Script
Dear,
I’m trying to create a pipe from a definied line. I’m trying to get it using the MEPover Node called Pipe.ByLines but I always get “null” result. Find Image below.
I’m trying to findout the problem on the Python code, but I couldn’t find any trouble.
clr.AddReference(“RevitAPI”)
if isinstance(IN[0], list):
lines = IN[0]
lines = [IN[0]]
FirstPoint = [x.StartPoint for x in lines]
SecondPoint = [x.EndPoint for x in lines]
if isinstance(IN[1], list):
pipetype = UnwrapElement(IN[1])
pipetype = [UnwrapElement(IN[1])]
ptl = len(pipetype)
if isinstance(IN[2], list):
systemtype = UnwrapElement(IN[2])
systemtype = [UnwrapElement(IN[2])]
stl = len(systemtype)
if isinstance(IN[3], list):
level = UnwrapElement(IN[3])
level = [UnwrapElement(IN[3])]
ll = len(level)
if isinstance(IN[4], list):
diameter = IN[4]
diameter = [IN[4]]
dl = len(diameter)
elements =
for i,x in enumerate(FirstPoint):
try:
levelid = level[i%ll].Id
systypeid = systemtype[i%stl].Id
pipetypeid = pipetype[i%ptl].Id
diam = diameter[i%dl]
pipe = Autodesk.Revit.DB.Plumbing.Pipe.Create(doc,systypeid,pipetypeid,levelid,x.ToXyz(),SecondPoint[i].ToXyz())
param = pipe.get_Parameter(BuiltInParameter.RBS_PIPE_DIAMETER_PARAM)
param.SetValueString(diam.ToString())
elements.append(pipe.ToDSType(False))
except:
elements.append(None)
OUT = elements
May someone help me?
Thanks in advance
You should only use the ‘Element.Name’ node to help you choose the correct pipe (system) type. The node expects a pipe (system) type and not a string (the Element.Name node returns a string).
Thanks @T_Pover already works, but only on Revit 18.x
If I try to run the routine on Revit 19.x it gets completely freeze. I guess It’s a Python Code problema.
clr.AddReference("RevitAPI")
lines = IN[0]
lines = [IN[0]]
ptl = len(pipetype)
ll = len(level)
diameter = IN[4]
diameter = [IN[4]]
dl = len(diameter)
elements = []
try:
except:
OUT = elements
I Have to check it out again.
Try this code adds pipes and sets diameter
import sys
sys.path.append(‘C:\Program Files (x86)\IronPython 2.7\Lib’)
import System
from System import Array
clr.AddReference(“RevitAPIUI”)
Current doc/app/ui
app = uiapp.Application
Define list/unwrap list functions
def tolist(input):
result = input if isinstance(input, list) else [input]
return result
def uwlist(input):
return UnwrapElement(result)
Preparing input from dynamo to revit
pipeTypes = uwlist(IN[0])
PipingSystemTypes = uwlist(IN[1])
levels = uwlist(IN[2])
stPoints = uwlist(IN[3])
enPoints = uwlist(IN[4])
ppDia = IN[5]
#element = tolist(IN[1])
#element = tolist(IN[2])
output list
newPipe=
pipeElements=
#Start Transaction
your actions
for i in range(len(stPoints)):
pSysTypId = PipingSystemTypes[0].Id
pTypId = pipeTypes[0].Id
lvlId = levels[0].Id
st = stPoints[i].ToXyz()
end = enPoints[i].ToXyz()
NewPipe = Autodesk.Revit.DB.Plumbing.Pipe.Create(doc, pSysTypId, pTypId, lvlId, st, end)
param = NewPipe.get_Parameter(BuiltInParameter.RBS_PIPE_DIAMETER_PARAM)
param.SetValueString(ppDia.ToString())
pipeElements.append(NewPipe.ToDSType(False))
#End Transaction
Preparing output to Dynamo
OUT = pipeElements
