In this part, thank you for helping me solve the problem of FamilyInstance.ByPoint.
Hello, everyone
In the picture, I built a multi-storey model.
[image]
I am going to try to place components periodically.
At the beginning I grabbed the height of each floor and gave the coordinates.
And use the List.GetItemAtIndex node to grab points and place the component.
But I found that the output of index=0 and index=1 will only be placed in the index=0 position.
Has anyone ever had this happen?
[image]
[image]
place-component with periodicity.dyn (28.5 KB)
place component model.rvt (3.5 MB)
But I found that when the program is executed,
The components placed in the previous loop will be overwritten and will not remain in the model.
Is this a normal situation?
Is there a way to keep the components?
A quick question, why do they need to be placed periodically? And not through some List.Lacing to longest?
This is just the test I want to do now.
I mainly want to solve the overwrite problem.
do you mean the element binding problem?
Is there an easy way to run a dynamo definition multiple times and have it write new element Id’s and not over write the old ones? I am placing CW panels by points on 2 towers and each time I write it removes the other tower panels. I get that in some cases you would want to edit the element that you just created but how do you remove the connection between dynamo and the element created?
It is an elememt binding issue. You have two options.
Use the timing to pull the level list/points and feed that to the element creation node.
Use a transaction to force each element to be created and released by Dynamo.
Sorry, I don’t quite understand the meaning of these two methods.
