PAth array.dyn (29.2 KB)
Hello everyone, Currently I have this dynamo script which is like a path array in AutoCAD, In which we select a path(model Line for example ) and a family (columns for example ) and assign the families to follow the specific path ( model Line) my problems/questions are :
1-This script is currently placing the families at Level 1or level 2 etc. … , but I want also to specify the levels parameters . For example when I am assigning the families on this path I want them also to be placed from level 1 till level 3 for example or from level 1 till level 4 etc…
2- How Can I create a specific distance between each family . ( assign the families on this path with a distance of 1 meter between each family for example )
Path array with Levels.dyn (25.5 KB)
Thanks Kim, But do you know what’s is the problem here I , the families/concrete columns are not being placed From level 1 till level 3 for example
Then, you have to make translated points for each level using Level.Elevation node.
Thank you so much for your help but I didn’t get you exactly, I am really new to dynamo . what exactly do I need to do . Where should I use the Level.Elevation node
Before that… why the last node of mine retuns null??? it shoud be sloved first.
See attached… It’s not very complicated… but it’s complicated in words… ![]()
Enjoy. ![]()
Path array with Levels_EnjoyRevit.dyn (37.2 KB)
Thanks a lot Kim You are the best . It is working just a simple question can it place one column from level 1 to 3 for example , not two columns one from level 1 to 2 and one from 2 to 3 ?Only one column from level 1 till 3
Again I really appreciate the help
Then, just place a column at start level, and change Top Level paramter of the Column using SetParameter. You need to use upper level of the last one in this case.
Thanks a lot Kim . Wish you the best
Path Rotation Distance.dyn (49.3 KB)
Hi Kim again thank you for your help , but do you know how I can combine the concept of this script with the one you just gave me . The dynamo script here is a path array which rotates objects , but at the same time I want them to be placed from level 1 to 3 like the one you gave me .
the help
Now I have no pc. You’d better study a little more about Dynamo nodes first. No offence, but there is no one who can build your whole graph here.
Thanks for the advice . I appreciate the help though . I will try and learn more about dynamo nodes
