I’m trying to do a list with all parts and your respective room.
I wrote what I’m doing in the image below, and sent my dyn file.
Ambientes.dyn (16.9 KB)Hi,
Ambientes.dyn (16.9 KB)You could try something like this:
Yna_Db,
Thanks for the help.
I just couldn’t try yet because the node GET REVIT ACTIVEVIEW i didn’t find.
Get Revit ActiveView is from Hot Gear, and alternatively, Active View is from SpringNodes. Just type “active view” in the browser search field.
I was also thinking that this workflow will only work with simple shapes, but it’s certainly enough to start a discussion…
Edit: an option would be to place a raybounce at each boundary curve mid point in the direction of the normal
I stoped to try this, now I’m back.
Can u help me again?
I still needing to get all parts in each room.
do you want to discard the framing / studs / anything not a finish layer here? If so I think you can use a Boolean filter for Geometry.Intersects with a room geometry and parts to get only the facing finish. Worth a try anyway. I reccomend you use the intersection check from bimorph as it’s faster.
Jacob,
I tried by this way.
At the first time, when I had 3 parts and 1 room, worked fine.
When i runned in a project with a lot parts and rooms… not!
Screenshot isn’t reading node names or outputs, can you repost with the first error expanded?
Looks like you are missing a few inputs…
Try this:
i saw this yesterday kkkk
i will try and see the results, and back here to say if is working.
thank you!!
I’ve encountered the same problem as @daniel.petrin faced when using BoundingBox.GetElementsIntersect node.
Does anyone knows the possible solution?
@Sam_Dehghani what is the error you are getting on the BoundingBox.GetElementsIntersect node?
I got it from another way… much better!
if you check EXCLUDED (see red arrow), another ghost part is created.
So, I got another nodes to leave only REAL PARTS in the lists.
ROOM AND PARTS.dyn -> listing all parts
ROOM AND REAL PARTS.dyn -> filtering somethings and filtering ghost parts
Room and Parts.dyn (15.8 KB)
Room and Real Parts.dyn (32.7 KB)
Hi @awilliams
It says that there’s no geometry or it’s been deleted.
The workflow was working all right, however when I opened another Revit file it started to show errors and did’nt stop until I closed Revit.
@Sam_Dehghani if @daniel.petrin’s solution with .dyn files above doesn’t solve the issue you’re having, I’d recommend starting a new thread
Khalid,
To list each parts from each room, don’t need extra packages…
Did you try?
I tried now, it’s working…
