Parking Numbering only without python
I’d like to share the solution for Revit parking numbering using Dynamo. I guess this would be a duplicate topic but it’s worth giving a shot. I managed to shorten loading process and minimize unwanted nodes.
I cannot upload since I am new user. Here’s a weTransfer link:
https://we.tl/s5Xl38Lxr3
Open for suggestions.
Only one more thing to be perfect: a node for prefix. For example a prefix for level of parking (ex. **-2.**45).
Regards.
Thx, hear are the files:
Parking Auto Numbering.dyn (32.4 KB)
How to use Parking Auto Numbering.pdf (163.9 KB)
Here’s doesn’t work…
Parking Auto Numbering.dyn (33.7 KB)
rmiguel here’s your request, my apologies for late reply. Got a little busy :smiley:
Doesn’t work here @abfletcher. I run the script and don’t put a mark in parking slots.
Parking Auto Numbering-2.dyn (29.4 KB)
@rmiguel I made changes again, noticed that some of the node results varies depending on the version of Revit and Dynamo, so I made changes to make it compatible with any version somehow, hope this one works for you.
Not working yet…
As you can see, I run the script and don’t put the number in Mark parameter.
create multiple lines instead of a single spline, and create it across near the center of each parking as shown in the image.
@abfletcher the script works awsm. I had a quick question, is there a way we can make it work on multiple levels automatically. Thanks.
Helllo @abfletcher @archamby, @Fiesta
I tired following the given instructions and running the script but the scrip gives an error message, could you please check with this?
Thanks.
Parking Auto Numbering.dyn (33.7 KB) Kindly find the attachment of the revit and dyn script for better understanding.
Project1.rvt (1.3 MB)
Thanks again.
I created this using Millimeters, and i see yours is in imperial. Just change the circle radius of 1000mm to 3 ft and should work
Hey,
Thanks for the correspondence.
Actually I cracked it. It works perfect now.
I am trying to use your Script in Revit 2025 Dynamo 3.2.2. No error shows up, run of the script is completed, however nothing happened in Revit. It didn´t numbered my tags. Could you give me some advice how to solve it please ?
