Can anyone give me the code for this node? I get CTD when I use Node to Code…
And code for Parameter.Name and Element.SetParameterByName nodes
When i try to use “node to code” Dynamo 1.3.4 crashes also.
You could try this:
Maybe it works for you.
Actually, it should work for me too … but maybe it’s up to my dynamo.
Seems to be a conflict with add-on packages, I have Orchid, Rhythm & archilab loaded…
…so need a syntax which I haven’t found yet.
