I have some problems with the “Parameter Type” while using the Parameter.CreateSharedParameter or Parameter.AddSharedParameter nodes. Why is “Text” an invalid Parameter Type? I also tried the Select Parameter Type node, but it ends in the same Issues. Look the imagens below:
The string with : I think a parameter can not have that charater
I ran into this same error with an Orchid node but the problem turned out not to be the type category. It’s probably actually your Group input. I assume “Dados” is a translation for Data (?), so you need the Revit internal group name of “PG_DATA”. Make sure it is all capitalized.
Hi Adam,
Were you able to solve it? I have the same problem.
