Add shared parameter error
Please help me, fix the dynamo I created, if in Revit version 2021 I managed to use the group parameter.
check out the input types, pin 1 expects single string (string array is given) and pin 3 expects single string (GroupType is given)
Hi @cucu.s.rukmana and welcome…that looks like a custom nodes where is that from ? in 21 if i remember we used PG_grouptypes, in newer builds is it spec.grouptypes…but not sure if it could be the issue
I don’t know if this is any help but i use the node from Orchid in Revit 2024.
Not sure if Orchid was already available for Revit 2021.
In 24 and 25 i use this one here from @c.poupin Create new family parameter - #13 by c.poupin and work like a charm, thanks Cyril :wink: i have just modified it a bit with a input document so it can work in BG open as well…
This is way i like to post what I use. If others do to i know what is out there (alternatives)
and what is working or not working.
yeah 100…crumple have some nodes for that as well, havent tried, but hear from others it work as well
Share me please dyn data :grin:
thats what i already have done, use the link to Cyrils post and there you have some solutions…
