Node usage Parameter.CreateSharedParameter with many categories
it only takes the first one - IN[0]
how to change to have more categories?
Thanks for help
@ Mark.Ackerley
Thanks … it works
I read some posts —> wanted “long” option
@erfajo
Thanks for collaboration
Hi @erfajo,
I am just hugely indebted to All of you package creators, so I can’t criticise
@alex_volt if the post solved your problem, it would be handy to mark it as Solved, incase anyone else has this issue.
Cheers,
Mark
I think in this case - the node is performing as it should - longest lacing will replicate over the list of categories, which will run the node N times, each time with one item from the list of categories. Shortest or Auto I believe will get the proper behavior where the list is passed as is, and the function will execute once.
@Mark.Ackerley how can i mark —> solved?
