Hi
Im wanting to write some shared parameters to multipule catergories at the same time, is this possible?
i have sucessfully pushed the parameters i want through to doors but when i try to apply them to another catergory eg. windows the previously created parameters are removed from doors.
im sure its a rookie mistake but im totally stuck her
That’s actually normal Dynamo behaviour. If you switch the category, your graph will affect another category instead of the previously selected category.
There are several approaches you could take:
- - Feed a list of categories to the shared parameter node (depending on how that node was designed this may already work)
- - Create duplicates of your workflow for each category (good for beginners because there's not a lot that can go wrong with this approach)
- - Use List.Map to feed a list of categories to the shared parameters node (more elegant than approach #2, but this would require an understanding of how the List.Map node works - do a search on this forum and something should come up)
Thanks for the reply-
I have now tried with duplicates og the graph for multipule categories which actually worked well.
But i will now look into the list.map node to see if i can make a little simpler solution.
a little bonus question - is it possible to push a shared parameter to all revit categories ?
With Dynamo, you would have to create a list of all categories and then adapt your graph to process that entire list (approaches #1 or #3), but there’s no node that will give you a complete list of categories - which means manual work. I believe there are some Revit addins that allow you to specify multiple categories when creating project parameters but I can’t say for sure.
I tried creating my own script which adds multiple parameters from a shared parameter to a multiple categories inside a project and it works fine.
Understood, just following up the convo above. for people like me who are new to dynamo world and looking for answers. thanks @erfajo
