Dynamo node OverrideGraphicSettings.ByProperties is not accepted as input by Python Node?
Hey,
I encountered an issue while trying to override elements graphics in specified view with python.
The OverrideGrapicSettings is created by dynamo node OverrideGraphicSettings.ByProperties (easier to maintain large amount of overrides and editable for non python friendly users). While pushed in to python code, whether wrapped or unwrapped, it creates a following warning:
*Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. *
  • File “”, line 34, in *
    TypeError: expected OverrideGraphicSettings, got OverrideGraphicSettings
From existing posts, I saw users having similar issues, and ending up creating the OverrideGraphicSettings in code. I would like to avoid that. Is there a way to make the 2 work?
A screen and code used in the workflow is attached.
Thanks for the help :slight_smile:
import sys
# Load RevitAPI library
clr.AddReference("RevitAPI")
# Load Libraries to access Revit Document and open Transactions
# Get Current Revit Document
# Open Transaction
view = UnwrapElement(IN[0])
overrideList = UnwrapElement(IN[1])
elementList = UnwrapElement(IN[2])
checkList = []
for override,element in zip(overrideList, elementList):
	#try:
		view.SetElementOverrides(element.Id, override)
		checkList.Add(Element)
	#except:
		#checkList.Add("Override Failed")
OUT = checkList
Hello @kpeJ6UMS and welcome
You need a Autodesk.Revit.DB.OverrideGraphicSettings class instance instead of Revit.Filter.OverrideGraphicSettings
the UnwrapElement method do not convert it
try to use this node
