This works great to override elements the active View but I want to do it on multiple views at once. Is there a node available to do it?
This Python is a clue but I could not figure out the lacing/looping.
clr.AddReference('RevitAPI')
view = UnwrapElement(IN[0])
element = IN[1]
override = IN[2]
result = []
count = 0
while (count < len(override)):
for i in element:
try:
view.SetElementOverrides(i, override[count])
result.append("Success")
count
count = count + 1
except:
view.SetElementOverrides(i, override[count-1])
OUT = result
Untested. But what if you use the python you posted, and loop the IN[0] over the TransactionManager?
(Btw: perhaps you could map the original node as function?)
views = UnwrapElement(IN[0])
element = IN[1]
override = IN[2]
result = []
count = 0
for view in views:
for i in element:
try:
count
count = count + 1
except:
sorry lacking the time atm to help you. Perhaps others can!
Tried it myself: I see you are using dynamo 2, doing that myself too:
- line 34 error: GraphicOverrideSetting isnât a list, so no need to loop that.
- if you fix that: you get an error: âExpected GraphicOverrideSettings, got GraphicOverrideSettingsâ ⌠so⌠that isnât helpfull.
- tried creating a GraphicOverrideSettings myself with a color. ⌠same error. Expected Color, got Color. âŚ
Hmm. I found some more clues and will keep trying.
Another clue from Element color override in viewS
Issue opened 2017
https://github.com/DynamoDS/DynamoRevit/issues/1812
Try to use âi.Idâ not just âIâ.
The Clockwork node View.OverrideElementTransparency works as expected but only if I set its lacing to longest. I think I can hack it.
How to make this Python script by itself lace longest as there is no lacing setting on its node?
Hey @truevis,
You need to include the views in the looping process. Can you not implement what I did I the post you linked to?
Otherwise, it would be helpful, if we could see your list structure. Iâm not at a computer right now, but I might be able to help you out tomorrow, if you canât make it work
Hi, @truevis! I cant help you with this DynamoNodes, but you can try solution with python. Here is short example:
And also code for copy/pasting:
import clr clr.AddReference("RevitAPI") from Autodesk.Revit.DB import OverrideGraphicSettings, Color clr.AddReference("RevitServices") import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager doc = DocumentManager.Instance.CurrentDBDocument elements = UnwrapElement(IN[0]) views = UnwrapElement(IN[1]) line_pattern = UnwrapElement(IN[2]) fill_pattern = UnwrapElement(IN[3]) color_input = IN[4] color_l= color_input.split(" ") color = Color(int(color_l[0]),int(color_l[1]),int(color_l[2])) TransactionManager.Instance.EnsureInTransaction(doc) for i in elements: for view in views: ogs = OverrideGraphicSettings() ogs.SetProjectionLineColor(color) ogs.SetProjectionFillColor(color) ogs.SetProjectionFillPatternId(fill_pattern.Id) ogs.SetCutFillPatternId(fill_pattern.Id) ogs.SetCutLineColor(color) ogs.SetCutFillColor(color) ogs.SetHalftone(False) ogs.SetProjectionLinePatternId(line_pattern.Id) ogs.SetCutLinePatternId(line_pattern.Id) ogs.SetSurfaceTransparency(IN[5]) view.SetElementOverrides(i.Id, ogs) TransactionManager.Instance.TransactionTaskDone()
And here you can get other graphic override settings OverrideGraphicSettings Methods
That looks close but we are providing list of lists for the model elements. That listâs top level has the same count as the list of Views. Each sub-list has the elements to be overridden in each View.
Iâm just not good yet on the looping in Python to make it the equivalent of longest lacing in a node.
Ok, so can you give an example of final list in this way:
LIST LIST: View View View LIST: Element Element Element
Is it something like that?
list:
->view 0
->view 1
->view 2
list:
->list of elements to override in view 0
->list of elements to override in view 1
->list of elements to override in view 2
overrides (from node)
I think now its ok, so here we go:
python code:
import clr clr.AddReference("RevitAPI") from Autodesk.Revit.DB import OverrideGraphicSettings, Color clr.AddReference("RevitServices") import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager doc = DocumentManager.Instance.CurrentDBDocument input_list = IN[0] views = UnwrapElement(input_list[0]) el_top_list = UnwrapElement(input_list[1]) line_pattern = UnwrapElement(IN[2]) fill_pattern = UnwrapElement(IN[3]) color_input = IN[4] color_l= color_input.split(" ") color = Color(int(color_l[0]),int(color_l[1]),int(color_l[2])) line_weight = IN[6] halftone = IN[7] ogs = OverrideGraphicSettings() ogs.SetProjectionLineColor(color) ogs.SetCutLineColor(color) ogs.SetCutLineWeight(line_weight) ogs.SetProjectionLineWeight(line_weight) ogs.SetHalftone(halftone) ogs.SetSurfaceTransparency(IN[5]) #ogs.SetProjectionFillColor(color) #ogs.SetProjectionFillPatternId(fill_pattern.Id) #ogs.SetCutFillPatternId(fill_pattern.Id) #ogs.SetCutFillColor(color) #ogs.SetProjectionLinePatternId(line_pattern.Id) #ogs.SetCutLinePatternId(line_pattern.Id) TransactionManager.Instance.EnsureInTransaction(doc) count = 0 for k in range(len(views)): for i in el_top_list[count]: views[count].SetElementOverrides(i.Id, ogs) count+=1 TransactionManager.Instance.TransactionTaskDone() OUT = 0
Aâm glad it works for you. As you sad you need input list for elements:
LIST LIST Element Element LIST Element Element
If you select only one element dynamo node create something like:
LIST LIST Element Element Element
So your task is to create correct input list with nodes. But for my example you can add another python node:
out_list=[] for i in IN[0]: if isinstance(i, list): out_list.append(i) else: out_list.append([i]) OUT = out_list
Wish you to fulfill your task !
This is great! But it doesnât seem to work for annotation elements (such as Revision Clouds). Is there any way to override those in multiple views? (I created a new topic about this) Thank you!
@Dmytro_Serebriian
What do i have to change in this Python to only override the Fill Patterns.
I donât want to override the color of the Lines.
NB I know Dynamo, but not Python.
EDIT I think i found out myself
fill_pattern = UnwrapElement(IN[2])
color_input = IN[3]
for i in elements:
for view in views:
ogs.SetSurfaceTransparency(IN[4])
Here is a Python hack to turn a single selected element into a list if needed:
if isinstance(IN[0], list):
out_list=IN[0]
out_list=[IN[0]]
OUT = out_list
Thence the Python for the overrides works if only one element selected.
input_list = IN[0]
line_pattern = UnwrapElement(IN[1])
color_input = IN[3]
line_weight = IN[5]
halftone = IN[6]
count = 0
count+=1
OUT = views
