I am new to Dynamo and started liking it, I am currently working out the nodes that @Einar_Raknes created, my objective is to load about 40 M&E services and assign the color codes in it. My initial run was successful, it did follow my assigned colors thru RGB, however, the second run was not the same as my initial run, I have noticed that the colors are mixed up. The question now is, is there any nodes or method that I can load the specific M&E Services then apply the color codes and line weight as well in the Override Filter.
Or pls give me a link that is the same topic as this.
Below is my current nodes for your perusal & comment
Thank you in advance.
Vincent
