Ordering List by Parameter Value (Sheet Number)
Hey guys!
I working on a code to export sheet data to excel (which I have working) but I am having a lot of trouble trying to re-order my list to be in order of sheet number (from lowest to highest) and not by the sheets index. I have been going around in circles trying to make this work.
My node setup prior to export currently goes:
list create > list.transpose > data export
and that spits out excel like the below:
Any help would be great! Though I know you can re arrange the list in excel but id like to have it embedded in the code
Node setup of the list for reference
Are you pulling the data from schedules or categories?
Can you please explain a bit futher?
Sorry but here is a link to the graph file https://we.tl/t-MVosa0mG4X
I am pulling from categories as the image below shows. Does pulling the data from schedules change how the data would get sorted? Excuse my daftness
yes it does, (btw) your not daft apperently
read this:
thanks heaps!
I will need to do a bit of reading and figuring out to understand that list sort by key node but thank you for your help!!
It works! The only sheet that gets lost in the fray is sheet 1000 which gets put after sheet 100 instead of at the end of the set, but having everything else in order makes it so much easier! thank you heaps for you help
Ahhh! I had literally downloaded the Orchid package about 10 minutes before posting this. Will need to play around with the Natural sort order, and probably do a bit of research so I properly understand the different types of sort order.
Thank you so much for you help!
