I am trying to use a delete node to delete all instances of a specific family type only to add this exact family type back later in the graph. My issue is that the delete node seems to be running after i create the new families even though it is placed at the start of the graph, before the nodes that even create the new families.
On the same subject, i am trying to create an element and then modify that element later in the same graph as opposed to running a new graph to modify it, is there a node that will allow the graph to pause so the element can be created, and then resume to allow the newly created element to be modified?
