Orchid installer?
I saw Orchid installers on Github and, naturally, I checked the EXE I wanted on Virustotal before running it. Report: VirusTotal
Perhaps false malicious warnings, but I am trying to figure out other ways to install Orchid. It looks like a wonderful package that is very useful. Online Package Search does not seem to work:
This is confusing. I am looking for the Revit 2022.1 version:
Is Zipped/Orchid_212_Revit.zip correct?
It’s Orchid not Orchard. Yes. Use 7-zip archiver.
Best to discuss this with the package author on their github.
Generally, I do not get involved with discussions regarding this specific package. However, this does seem to be a common theme on VirusTotal regarding installers created with InnoSetup.
See this stack overflow post here:
In the past, we have often suggested that people only install packages from the Dynamo package manager, (which I still suggest for most users and packages).
However, with the way the package manager operates (awfully), I sympathize with Erick on this issue. For him to ensure that his package experience is consistent for users, creating an installer was just about the only option he had.
I have been struggling for months to update Rhythm in a way that allows for use from Revit 2021-2024, and I almost started bundling my own installer as well. (I did manage to get it sorted out on the package manager I think, so we will see).
InnoSetup is a very popular installer creator and is available for free. The fact that we need to put/place files in locations that are deemed “risky”, ie. AppData generally causes flags on sites like VirusTotal. With programs like Revit add-ins and the like, we generally sign the installer, which helps. But, expecting someone to do that (:moneybag:) for a free Dynamo plugin is ridiculous.
As @jacob.small said, if you see the results of VirusTotal being alarming to you, take it up with the package author directly. He does not use the forums or the package manager, so creating a post to show the results in a forum he does not visit, doesn’t seem fair.
And to directly address your initial ask of “which version for which Revit”, you would need to make sure you have the correct version for your Revit version. I track these myself here: Dynamo for Revit Version Masterlist - Design Tech Unraveled
That is a useful list. Is there a list of different versions of Dynamo installed from Revit hotfixes? I experienced many graphs breaking when hotfixing to Revit 2022.1 but I don’t know whether that was from a Dynamo version update or something else.
I only target the latest version available. I could include the point releases, but generally you should get those installed anyway.
Absolutely get those installed, if only for the infosec aspects…
