I tried to import openpyxl module through syntax
import openpyxl
from openpyxl import load_workbook
However python script warns that, “No module named openpyxl”
As you see i have installed openpyxl via cmd, but it still fails
Can someone help me?
with openpyxl lib you need to use the CPython3 engine
I did but it still fail
@thanhdatp297GRTHP you need to install the python modules this way
It looks like you have it installed on a python instance (3.11) that is not being used by Dynamo
You can find the install location OUT = sys.path which will return a few paths
C:\Users\<username>\AppData\Local\python-3.8.3-embed-amd64\python38.zip,
C:\Users\<username>\AppData\Local\python-3.8.3-embed-amd64,
C:\Users\<username>\AppData\Local\python-3.8.3-embed-amd64\lib\site-packages
pip is not always the easiest module to install with Dynamo
Try this in a Python node with CPython3
import subprocess
import sysconfig
from pathlib import Path # python3 library
# Get file / exe locations for running Python install
pypath = Path(sysconfig.get_path("data")) # root path to python install
pyexe = pypath / "python.exe"
pipexe = pypath / "Scripts/pip.exe"
def getpip():
"""Install pip from the internets"""
if pipexe.exists():
return f"Pip already installed at {str(pipexe)}"
# Fingers crossed the enterprise firewall lets this through
comm = ["curl", "https://bootstrap.pypa.io/get-pip.py", "|", pyexe, "-"]
return subprocess.run(comm, capture_output=True, shell=True)
OUT = getpip()
You may have to reload the Dynamo graph to get access to pip, you may also have to uncomment the import site line in the python<version>._pth file (e.g. python38._pth) located in the python root folder (pypath above)
Then you can install from a list or string of module names with a function something like this
def install(package):
comm = [pyexe, "-m", "pip", "install"]
if isinstance(package, str):
comm += package.split()
elif isinstance(package, list):
comm += package
raise TypeError("Input is not string or list of python modules")
I found the error, it seems like a conflict when I try to import both of openpyxl and AddReferenceByName(Microsoft.Office.Interop.Excel) at the same time.
I just remove command line AddReferenceByName(Microsoft.Office.Interop.Excel) and the code worked.
Thanks for all
