Opening cut geometry from window family
Does anybody know if it’s possible to extract the “Opening Cut” geometries from window (or door) family?
Please see the attatched image below.
Hi @Claus_Andersen
have a look at this script. I made this from similar scripts. I hope this help.
![window%20openings%20and%20schedule|690x379]
(upload://a6vNW01BtSEkdxZRCmrgyTVY9FL.jpeg)
Void Floor Rectangular Opening 2017.rfa (336 KB)
Hi @gregorio.palermo
Thank you for your response.
Unfortunately, i can’t use that approach, since there is no guarantee that the “Height” and/or “Width” parameter corresponds to the opening cut geometry.
I’m trying to do the same in order to add dimensions to existing window legend (which is basically an isolated section view for each window , done using dynamo of course). Did you have any luck with what you’re seeking ?
