I’m facing an issue when using the Element.GetLocation from OpenMEP, the coordinates i get from the element does not match the real location, and i’m having a hard time to understand why is this the case, could this be some sort of units?
As you can see the origin value in Revitlookup does not match the one from the node.
Does anyone have any ideas on what can be done so i can extract the correct values?
Hi @Nascimento guess all is alright
When i do with Normal Revit fittings i get the correct value, that only happens when i try to get the value from fabrication parts, do you have any idea if that occurs because of some sort of mixed unit or something?
@Nascimento can you send the example model you are facing ?
SAMPLE GETLOCATION PROJECT.rvt (6.1 MB)
Here is a Sample project that the same erros occurs @chuongmep
I tried using different units to see if any would match but the error aways occur only when using MEP Fabrication Fittings
Thank for your report, after review with this type, I saw have some missing need upgrade for this node to support for fabrication parts, I released a new version to fix for this problem more extend for fabrication parts
Link download OpenMEP latest :
Regard !
Thank you very much for all your support
