I came across this code a while trying to figure out how I can accomplish this.
Bulk Save as Central
I am very much a rookie to Python and so I was trying to figure out how I can tweak the code below to essentially open a family from a directory, and change the default view to 3D and then check the regenerate box.
I know the code is from working with central models and I deleted what I think I didnt need. I would also like to change the visual style to realistic. Any assistance would be very much appreciated it.
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.Attributes import*
from  Autodesk.Revit.UI import *
# Import Revit Nodes
# Import python library
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import os
from System.IO import *
app = uiapp.Application
SaveOptions = SaveAsOptions()
SaveOptions.MaximumBackups = 1
SaveOptions.OverwriteExistingFile = True
SaveOptions.Compact = False
SaveOptions = IsValidPreviewViewId()
SaveOptions.PreviewViewId = "View 1"
tOptions = TransactWithCentralOptions()
TransactionManager.Instance.ForceCloseTransaction()
filepaths = IN[0]
RVer = "R" + app.VersionNumber[-2:]
docpath = []
if IN[1] == True:
	try:
		for filepath in filepaths:
			file = FileInfo(filepath)
			filein = file.FullName
			modelpath = FilePath(filein)
			filename = filepath.Split("\\")[-1].Replace(".rfa","")
			newdoc = app.OpenDocumentFile(filepath)
			if RVer not in filename:
				if "Central" in filename:
					x = filepath.split("_")
					x.insert(len(filepath.split("_"))-1,RVer)
					y = "_".join(x)
					x = filepath[:-4]
					y = x + "_" + RVer + ".rfa"
				y = filepath
			newdoc.SaveAs(y,SaveOptions)
			newdoc.Close(True)
			docpath.append(y)
		OUT = [filepaths,docpath]
	except Exception,e:
		OUT = str(e)
	OUT = "Please set it to true"
