Open Family New Type, Save Close
Hi, the goal is to open a list of different Revit family annotation tags and add a new type 2.5mm text or change the 3mm type to 2.5mm and save. I am struggling with trying to get the label inside the open family to add a new or change the family type if anyone can help with that. Below is just me messing around trying to find somthing to do it with no luck. I’ve just pulled first item from list to save opening a bunch while trying to get it to work.
I guess it would have to save with the new created type selected. I’m assuming it would.
Hi Jeremy, how is it going? Can see you are always busy with Dynamo, haha.
The problem at hand here is that you are in a family doc, so the family is not an instance anymore, not placed in a project. I would do the following:
Get family types:
clr.AddReference('RevitAPI')
OUT = doc.FamilyManager.Types
And create new types inside the family doc:
from Autodesk.Revit.DB import Transaction
t = Transaction(doc, 'Name')
t.Start()
OUT = doc.FamilyManager.NewType(IN[0])
t.Commit()
And in case you wonder where you can get that info, here it is:
https://www.revitapidocs.com/2015/84156251-8912-e039-7784-8f93015b866a.htm
Happy new year!
Always having a headache with dynamo haha. This year is the year to do some Lynda tutorials on python in dynamo though. Happy new year! and thanks for some help. Although I don’t know python well enough to get anywhere…
I did this below. This may actually be to much if there is no nodes to do it.
I changed “Get Types In Family Doc” to try get family types of documents opened. However cant get it to accept lists
doc = (IN[0])
Then I was thinking, once those are selected. Can I add 2.5mm text type name
doc = (IN[0])
t.Start()
OUT = doc.FamilyManager.NewType("2.5mm")
t.Commit()
If that actually worked… I’d need another node to change the Text Size parameter before saving the document… :face_with_monocle: :thinking: :laughing:
Haha, that’s cool.
Without getting into the nitty-gritty, here is a quick and dirty script that will create a new type avoiding duplicates and returns the newly created types:
docs = IN[0]
types = []
for d in docs:
	types.append(d.FamilyManager.Types)
output = []
for doc in docs:
	t.Start()
	typeOut = None
	success = False
	try:
		success = True
	except:
		pass
	t.Commit()
	if success == True:
		typeOut = doc.FamilyManager.CurrentType
	output.append(doc.FamilyManager.CurrentType)
OUT = output
The params can be changed with the nodes as you usually do
Thank you so much for your help. Pretty powerful stuff… I’m just unsure how to get the correct out put to change the parameter of the new Type…
Ok, two options in here:
  1. If you are trying to change the size of the text in the label, well, you need to select the label and not the type of the family.
  2. Is there a parameter inside the type named Text Size that is linked to the label?
    If not, that is the reason the node is giving you an error.
Sorry for the confusion. Im trying to select the label inside the family. Create a new type and change the text size of that type inside the label
Sorry Jeremy, the problem is a bit more complex to solve it quickly, under the pump right now. The problem I have found is that Dynamo doesn’t support labels:
and I will have to workaround with a macro, for example, to get rid of the intermediary that’s Dynamo.
Maybe someone with more expertise, @solamour or @Michael_Kirschner2, can confirm us this?. Thank you guys.
docs = IN[0]
result = []
# Place your code below this line
for doc in docs:
	labelCollector = FilteredElementCollector(doc).OfClass(TextElement).ToElements()
	for e in labelCollector:
		if e.Symbol.ToString() == "Autodesk.Revit.DB.TextElementType":
			result.append(e.GetType())
OUT = result
your code literally gets the type of the object and returns it… but then you call Object.type() on a type… so type of a type… is a runtimeType!
why are you returning getType() instead of e
Hahaha, sorry, I should have provided a bit of context here. The idea is to retrieve the type of TextElement and duplicate it, so I called Duplicate(“name”) directly inside the python script but this error shows up:
And I though I should check what kind of object it is, that is the reason I plugged it into Object.Type
result = []
for doc in docs:
			result.append(e.GetType().Duplicate("New Type"))
Thanks for the link!
Why would a type object have a duplicate method - what type do you want that actually has a duplicate method?
Type - in .net - has no such duplicate method:
Oooh, so GetType() is not getting the Type of the Family Instance?
Thanks Michael, I think I have found a workaround.
Because funny thing, GetTypeId() and retrieving the element later by id gets the Type and allows me to use the Duplicate method.
docs = IN[0]
result = []
for doc in docs:
	t = Transaction(doc, doc.Title)
	t.Start()
			ft = doc.GetElement(e.GetTypeId())
			try:
				result.append(ft.Duplicate(IN[1]))
			except:
				if e.Symbol.ToString() == "Autodesk.Revit.DB.TextElementType" and e.Name == "2.5mm":
					result.append(ft)
				pass
t.Commit()
OUT = result
While using GetType() didn’t create any new type and returns this error when I try to modify type parameters:
docs = IN[0]
result = []
for doc in docs:
	t.Start()
			try:
				result.append(e.GetTypeId().Duplicate(IN[1]))
			except:
				pass
t.Commit()
OUT = result
Edit: the logic I was following was to get all TextElement, use GetType method inherited from Object, and use Duplicate method from TextElementType that is inherited from ElementType;
https://www.revitapidocs.com/2020/6990b86d-0b65-78c7-e4e6-1686e2ac28ed.htm
https://www.revitapidocs.com/2020/20896d19-a2a3-35b9-104e-89107fb2098c.htm
Thank you for all the help! looking forward to trying this soon!
