Hey all,
Been working for a few days on a python script to edit parameters (namely, text size) within a group of families from the parent file. Ideally I want to pass a list of file paths (or a directory -> contents all) to the node, have it update applicable parameters, save/update these files within the central file, and save the corresponding families back into a specified folder. I’m very close, but getting one error I don’t quite understand.
The full error is Line 60 - attempt to modify the model outside of transaction. I understand this error, but I’m not sure why it’s popping up. In the python code I call out specific lines before and after opening and closing the transaction - for some reason though, it’s only occurring on the families after the first - i.e. the first family updates correctly (and the transaction succeeds, code works exactly as intended) but all of the future families do not update (hence the line 60 error).
Please see screenshot and python code for further clarification. Apologies if my code is a bit blocky/bad… I am new to python and am trying to learn. I pulled bits of code from various places, so big shouts to @erfajo and @Konrad_K_Sobon for paving the way so I can piece together snippets of their code
import sys
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
import System
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
app = uiapp.Application
paths = IN[0]
par_name = IN[1]
par_value = IN[2]
class FamilyOption(IFamilyLoadOptions):
def OnFamilyFound(self, familyInUse, overwriteParameterValues):
overwriteParameterValues = True
return True
def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterVlaues):
return True
try:
errorReport = None
outValue = []
textnotes = []
for i in UnwrapElement(paths):
if "rfa" in i:
famdoc = app.OpenDocumentFile(i)
ownerFamily = famdoc.OwnerFamily
collector = FilteredElementCollector(famdoc)
ofType = collector.WhereElementIsElementType().ToElements()
for j in ofType:
output = j.LookupParameter("Type Name").AsString()
if output == "JQ Label" or output == "JQ - Typical" or output == "JQ - Standard":
textnotes.append(j)
output
for k in textnotes:
x = k.LookupParameter("Text Size")
TransactionManager.Instance.EnsureInTransaction(famdoc)
x.Set(par_value)
outValue.append(famdoc.LoadFamily(doc, FamilyOption()))
except:
import traceback
errorReport = traceback.format_exc()
if errorReport == None:
OUT = outValue
OUT = errorReport
