Hi guys!
I got a situation,I try to remodel the demark pavilion of 2010 EXPO in shanghai ,I had a good start ,but unfortunately I even don't know how to creat the spiral floor (how to loft the two curve as a surface in dynamo).Can you guys help me !Any help will be appreciated,Please see more detail from attachment.
Best
Aaron
Hi man
Thank for your help,yu are very kind of ,can I ask you what's the meaning of each inputs of the "Create Swept Geometry" Node.
Best
Aaron
I got it ,thanks for your help ,you are so nice!!
Best
Aaron
These long splines don't help. You need to shift your loft direction. Use pairs of points to create radial lines instead and then loft from those. If it still won't work, try shifting the index of your list of lines before you loft. And if that still doesn't work, there's a nice custom node called Sequential Loft that you can download through the package manager which should help.
