Only last item of the list is written to CSV
Hi guys, I am trying to create a list with running numbers and its contents (in this case sorted according to number in ascending order) in CSV format like below.
1 a 80
2 b 81
3 c 82…etc
Here is my attempt and everything seems fine until the write to CSV file. It appears null and only gives me the last item of the list. I do not know what went wrong.
Can anyone shed some light on this please? Thank you.
The list you are sending to the CSV is a step too deep at the moment, so you are actually writing the [item, pair of items] csv for every triplet of data.
Before your List.Join node you can use a List.AddItemToFront to our each item from the range into it’s own list, resulting in a list of lists with one item in each sublist.
The use a List.Flatten node with the list level set to @L2 to remove the extra level of depth.
Hi Jacob,
Thank you for your kind reply. I have tried according to your suggestion and attached below. However I didn’t get the outcome that I’m expecting. The good thing is my data is all written to CSV but the formatting is not what I expected. I must have done something wrong, can you please help me again? Thank you.
Try this?
TEST.dyn (27.5 KB)
Thank you Jowenn, it works!
Ah! Missed a @L1, but it wouldn’t have had the formatting you were after. Glad you’re squared away. :slight_smile:
Thanks for your time and effort tho :wink:
