Write list to .txt file
How can I successfully write this list of numbers to a .txt file? I searched several similar posts related to this but none of the solutions in the ones I saw worked. In my efforts in Dynamo I have tried leaving the list as it is, converting the integers to strings, joining the list to a single item with line breaks, and writing to a .csv. None have worked. I have a feeling I am not providing the data in a format which the node can work with. How can I prepare the data so the “write” node successfully places the text in the .txt file?
Why don’t you use Data.ExportExcel?
Hello @Redrunner262
You must join strings before
I only want these numbers to be placed on a notepad file, not an Excel file.
I tried that and it didn’t work.
It just worked. Just was testing different things and the above scenario produced results.
Thanks for your help!
The FileSystem.WriteText node is one of those areas where the output of the node isn’t clear, as “null” in this context means ‘nothing to worry about’. :slight_smile:
