Hi All,
I have two sets of lists and I wanted to omit the data which are already available in List 2.
Can anyone please help me with the proper node to use or how can I get the desired result.
below is the snip of two lists.
Hi @Draxl_Andreas
Thanks for your quick reply highly appreciated,
Actually, I do not want to have a unique value in the output.
I want to remove all the values from list one which are available in list 2.
hope you got my point.
Hi @Draxl_Andreas
In result I am interested in getting 4 and 5 as per your snapshot.
I have checked by creating same nodes as shown by you, in out node of List.FilterByBoolMask I am getting Empty List. can be seen in below snap.
Thank you so much @Draxl_Andreas
its working perfectly now.
Hi @ansarimdnazir & @Draxl_Andreas ,
Just FYI there is an OOTB node specifically designed for this:
This node also works if both lists are shuffled.
