Offset Revit Walls
any way I can the Revit’s offset command on some walls through Dynamo? I’m trying to offset walls of specific type by a distance. Big project, very tedious to do one by one. Thanks.
Once you offset the curves in Dynamo, you could use spring nodes’ Element.SetLocation node to overwrite the location curve of the walls.
Thanks a lot for the info on Element.SetLocation, Dimitar. Now offsetting the curves seems to be the issue following this post by me again
http://dynamobim.org/forums/topic/join-joinable-curves/
…ArchiLab is not working for version 1.0… any workarounds? please? Thanks again(for always)!
