Offset curve away from Internal finish line in same direction
Hi All
Can any one help to to offset curve in same direction facing away from internal finish regardless of wall position ?
im keep getting random results if wall finish side changes lines becomes
is this even possible ?
Regards
The directions of in/out side of walls depend on directions of location lines of walls.
You can find the directions you want using NomalAtParameter on location lines of walls.
Hi, @dkeinys
You can use this dynamo script. :point_down: To offset curve in the direction of wall face.
Hi Thanks for your time
Done as suggested but still get random results
Regards
Hi @dkeinys ,
Please change lacing to Auto and try.
I hope It may Work.
Hi Jaison, Thanks for your time again.
I have updated dynamo but results still same
Hi @dkeinys .
Use this node to get the wall exterior direction, I hope this will work!
Wall.ExteriorDirection From Archilab
Works As a dream thank you
