Hello! I’m trying to create closed polyline by doing an offset to a existing polyline. But when I aplly the offset, it just return a polyline with one curve (instead of ten).
In this post: Curve offset the node worked as i expected.
Troubleshooting geometry issues without access to the source geometry is problematic as it is entirely a guessing game. See if you can build a sample rvt to reproduce the issue and post that.
@sovitek I’ve tried this way too, but I get the same error:
I’m ataching the revit file and the code. Like @jacob.small said, it’s hard to say where is the problem without the knowing the origin of the geometry.
TEST1.rvt (5.2 MB)
DP_RVT - RD_ED_CRIAÇÃO-DE-VISTAS.dyn (70.4 KB)
The project has to be used as a link cause I get the room of the link file in the project.
