Offset a curve, masking region around it
Hey,
I still have a problem with generating a filled region with 2 closed curves
This is getting into advanced Dynamo… I don’t know of a node solution, here is a link to a Python based one…
I got it working…
Filled Region Loops.dyn (37.1 KB)
But you can see that the inputs are very particular, so you’ll need to test and likely edit the code to make work for your particular situation, it is possible that creating a custom node will help with levels issues.
Unfortunately, in my rvt file, neither all white solid region neither masking region do cover these ‘leaking’ .dwg underlays :frowning:
Without a test file I’m not sure whether I can help you further.
Cheers,
Mark
