Masking Region
Hi all,
Hopefully a simple question and most likely a dumb one on my part. Can Dynamo create a Masking Region (Like a filled region, not a filter mask)? I cannot find anything. I know Masks are filled regions. I can create a filled region with FilledRegion.ByCurves but I cannot figure it out how to get a masking region type.
Thanks,
Steven
I do not believe Masking Regions specifically are exposed via the API. You can use a Filled Region with solid fill, but that is only a workaround.
https://forums.autodesk.com/t5/revit-api-forum/create-masking-region/td-p/6843652
Thanks Sean for the confirmation.
