Object.Explode in Paper Space
I am trying to place a block of text attributes into my layouts and then explode the block so the fields will connect back up to a the connected sheet set manager. If I freeze the Object.Explode, then the block reference is placed into the Layouts/Paper Spaces. But once I unfreeze the Object.Explode, it will explode the block references and place them in model space. Thoughts?
Place Text Block and Explode.dyn (32.7 KB)
Hi @jbrunkhorst,
Looks like we need to improve this node to place the exploded objects within the same block as the source object. The current behavior is to place them in model space, like you identified.
