Hi, since I updated to C3D 2023 together with the new version of dynamo v.2.15.1 I’m not able to run the same script as before.
My scripts sweeps a circle curve along a path to represent underground cables as solids.
In the update I needed to change the Curve.SweepAsSolid node by a new version that adds a cutEndOff input. I put everything I need into that node, it creates a solid and now I want to export it to the drawing.
I use Object.ByGeometry for this and it used to work, but doesn’t now.
Did something else change in the update which I missed or is this a bug?
