I am looking to export .nwc for all project locations possible.
The code runs with no errors but the .nwc is not exported.
Please do share your view on this code.
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
import math
app = uiapp.Application
# Get the current project location
project_location = doc.ActiveProjectLocation
# Get the new location list from input
new_location_list = UnwrapElement(IN[0])
# Initialize a list to store the exported file paths
exported_files = []
#coll = FilteredElementCollector(doc).OfClass(ProjectLocation)
output = []
path = IN[1]
name = IN[2]
view = UnwrapElement(IN[3])
ChooseCoordinates = IN[5]
Linksbool = IN[6]
i=0
# Start a transaction
for new_location in new_location_list:
name1 = name[i]
#Set the new project position
project_location.SetProjectPosition(XYZ.Zero, new_location_list[i])
location=new_location_list[i]
#path = Autodesk.Revit.DB.FilePath(pathName)
Options = Autodesk.Revit.DB.NavisworksExportOptions()
Options.ExportScope = NavisworksExportScope.View
Options.ViewId = view.Id
Options.ExportLinks = Linksbool
Options.Coordinates = ChooseCoordinates
Options.ExportParts = False
Options.ExportElementIds = True
Options.ConvertElementProperties = True
Options.ExportRoomAsAttribute = True
Options.ExportRoomGeometry = True
Options.ExportUrls = True
Options.DivideFileIntoLevels = False
Options.FindMissingMaterials = True
doc.Export(path, name1, Options)
i += 1
exported_files.append(name1)
#TransactionManager.Instance.EnsureInTransaction(doc)
doc.Regenerate()
# OUT = dir(Autodesk.Revit.DB.NavisworksExportOptions.ExportScope)
OUT = exported_files
