I found an earlier form with a custom node that allowed you to export the active view to an NWC. Im trying to modify the code so that i can select the view i want to export instead of exporting the active view. Im just started learning how to code and i really dont know where to start.
I want to add something like this so i get a new input.
Here is the code:
Import ToDSType(bool) extension method
Import geometry conversion extension methods
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
import System
import math
app = uiapp.Application
coll = FilteredElementCollector(doc).OfClass(ProjectLocation)
output =
path = IN[0]
name = IN[1]
#path = Autodesk.Revit.DB.FilePath(pathName)
Options = Autodesk.Revit.DB.NavisworksExportOptions()
Options.ExportScope = NavisworksExportScope.View
Options.ViewId = uidoc.ActiveView.Id
doc.Export(path,name , Options)
doc.Regenerate()
#OUT = dir(Autodesk.Revit.DB.NavisworksExportOptions.ExportScope)
OUT = 0
