Navisworks Export through Python
Hi all,
I have been attempting to export objects to Navisworks using python. The script runs without errors, but I am not seeing an exported .nwc at the specified location.
Files attached
Direct Shape Python test.dyn (14.5 KB)
DirectShape Python.rvt (388 KB)
Python below:
clr.AddReference('RevitAPI')
clr.AddReference('System')
dataEnteringNode = IN
solid = IN[0]
category = UnwrapElement(IN[1])
solidList = []
solidIds = []
catId = category.Id
for i in range(len(solid)):
	ds = DirectShape.CreateElement(doc, catId)
	ds.SetShape(solid[i].ToRevitType())
	ds.Name = "This is the Name"
	solidList.append(ds)
	solidIds.append(ds.Id)
TransactionManager.Instance.ForceCloseTransaction()
fileLoc = "C:\Users\proberson\Desktop\dyn test"
fileName = "Test"
navOp = NavisworksExportOptions()
col1 = List[ElementId](solidIds)
navOp.SetSelectedElementIds(col1)
navOp.ExportScope = navOp.ExportScope.SelectedElements
navOp.ExportRoomGeometry = False
doc.Export(fileLoc, fileName, navOp)
OUT = solidIds
I figured this one out. I just moved the TransactionManager.Instance.EnsureInTransaction(doc) line to below the doc.Export line. I am not sure why this changed the outcome…any thoughts on that would be helpful. Hope this helps someone in the future.
There are a few additional lines in the code that are disassociated with solving this issue.
solid = IN[0]
names = IN[2]
catId = category.Id
dsId = []
	ds.Name = names[i]
	dsId.append(UnwrapElement(ds.Id))
fileLoc = IN[3]
fileName = IN[4]
col1 = List[ElementId](dsId)
doc.Regenerate()
doc.Delete(col1)
doc.Regenerate()
OUT = 0
Do you know any way to export NWC from Multiple Sites existing in revit?
I change this in a loop and then try to export NWC, sites changes but no export file is done.
clr.AddReference(‘RevitNodes’)
clr.AddReference(“RevitAPI”)
import Autodesk.Revit.DB as db
allLoc = doc.ProjectLocations
allLocNumber = allLoc.Size
enum = allLoc.GetEnumerator()
enum.MoveNext()
sol = enum.Current
folderpath = IN[0]
viewEx = UnwrapElement(IN[1])
def ProcessParallelLists(_func, *lists):
return map( lambda *xs: ProcessParallelLists(_func, *xs) if all(type(x) is list for x in xs) else _func(*xs), *lists )
allLocations = [sol]
for loc in range(allLocNumber)[:10]:
enum.MoveNext()
sol = enum.Current
allLocations.append(sol)
options = db.NavisworksExportOptions()
options.ViewId=viewEx.Id
#All,Elements, or None
#options.NavisworksParameters = Enumeration
options.ExportScope = db.NavisworksExportScope.View
options.ExportLinks=False
options.Coordinates= db.NavisworksCoordinates.Shared
options.ExportParts = False
options.ExportElementIds = True
options.ConvertElementProperties = True
options.ExportRoomAsAttribute = True
options.ExportRoomGeometry = False
options.ExportUrls = True
options.DivideFileIntoLevels = False
options.FindMissingMaterials = True
def moveAndExport(loc):
fileName = doc.Title + “_” + loc.Name
doc.ActiveProjectLocation = loc
doc.Regenerate()
result = doc.Export(folderpath, fileName, options)
return fileName
ProcessParallelLists(moveAndExport, allLocations)
OUT = [x.Name for x in allLocations]
