Hi everyone
I been working recently with Dynamo, im creating some form based on Nurb Curves, i use splines in a Mass in Revit plataform, and then i select the splines in Dynamo add points to the lines so i can control them and by using points i create nurb curves:
However i have 2 questions or problems with this:
1.-How can i create a mass form in dynamo, in a line (basic Revit mass form or adaptive components), as if i create a spline in revit, add a point, draw a rectangle, and create form.
2.-i have this warning message that nurbsCurves require at least 2 points for intepolation. It looks like the form works fine, so i dont really understand the reason for the text.
3.-Is i find the way to solve this, any tips to export the mass to revit
