NURBSCurve created in Dynamo not available in Revit
Hi everyone. I’ve created a NURBSCurve in Dynamo by control points, weights and knots.
Could you tell me why I cannot see it in Revit? Please find attached my file. I’m on the conceptual mass environment
Test1.dyn (44.6 KB)
Can’t read your nodes, so please post an image export of your graph after zooming in so they are legible. It’s the camera icon in the upper left of the workspace.
Likely you are seeing one of the following:
  1. Too big or too small to show up in Revit.
  2. Not creating a Revit curve from your Dynamo geometry.
I’ve tried two different creation methods from the API (this and this) with seemingly positive outputs, but neither create any actual geometry :frowning:
And even if these worked, they wouldn’t do you much good, since they only work in the project environment.
I did a quick browse through the family creation part of the API, and it looks like the only option is to create a CurveByPoints() . I’m no expert on geometry, but I do not believe that is what you are after. It did yield geometry in the mass environment though:
I don’t know if you can use it, but this is the content of the python script:
import System
#Import the Revit API
clr.AddReference('RevitAPI')
#Import generic collections
clr.AddReference('System')
#Import DocumentManager and TransactionManager
#Import ToDSType(bool) extensions method
#Reference the active Document and application
#---###Start scripting here:###---#
pts = [i.ToXyz() for i in IN[0]]
rpa = ReferencePointArray()
#Transaction start:
for i in pts:
	rp = doc.FamilyCreate.NewReferencePoint(i)
	rpa.Append(rp)
curve = doc.FamilyCreate.NewCurveByPoints(rpa).ToDSType(False)
#Transaction end:
OUT = curve
I also had to scale your values with a factor 100, since if working with millimeters, your values are extremely small :slight_smile:
The content of the two python scripts that didn’t work for me is below, if anyone wants to have a go:
import System
iPts = List[XYZ]()
for i in pts:
	iPts.Add(i)
weights = List[System.Double]()
for i in IN[1]:
	weights.Add(i)
#Transaction start:
Hspline = Autodesk.Revit.DB.HermiteSpline.Create(iPts, False)
Nspline = Autodesk.Revit.DB.NurbSpline.Create(Hspline)
#Transaction end:
OUT = Nspline
The second attempt:
import System
iPts = List[XYZ]()
for i in pts:
	iPts.Add(i)
for i in IN[1]:
	weights.Add(i)
#Transaction start:
spline = NurbSpline.CreateCurve(iPts, weights)
#Transaction end:
OUT = spline
Hi @MartinSpence thank you for your answer!
