Can I install both Dynamo 1.0 and 1.2 at the same time. I have tried many times without sucess. It seems that installing Dynamo 1.2 will automatically uninstall 1.0.
If 1.2 is installed first then it will quietly not install 1.0
Can someone verify if this so. I do need to run bothe version as there are some old dynamo script that doesnt run in 1.2 .
Thanks for the help.
I am using REVIT 2015. Dynamo 1.2.1 still does remove older versions for REVIT 2015. Maybe someone will fix it for REVIT 2015 or possibly REVIT2016. I will try REVIT 2016.
@law Dynamo 1.2 will also work for Revit 2015. Is it possible for you to drop your DYN script which is not opening for you so that we can fix it for you.
