Normal vector Revit API
Hi All,
How to get Normal curve with Revit API if I have the following code?
St_pt = XYZ(2,2,0)
End_pt = XYZ(2,2,5)
line = Line.CreateBound(St_pt , End_pt )
Thanks.
You can use the ComputeDerivatives method from the Curve class, then interrogate the second derivative of the tangent vector by assessing the BasisY of the returned Transform object.
here is what i tried
Dynamo makes our job easier all the same
import sys
clr.AddReference("RevitAPI")
St_pt = XYZ(2,2,0)
End_pt = XYZ(2,2,5)
vec_a=XYZ(2,2,0)
line = Line.CreateBound(St_pt , End_pt)
a=XYZ(line.ComputeDerivatives(0.0,True))
vec_tang=a.BasisX
vec_norm=a.BasisY
vec_binorm=a.BasisZ
d=line.Direction
my_dico={"Point Revit-->":St_pt,
"Vector Revit-->":vec_a
,"Line Revit-->":line,
"vec_tang-->":vec_tang,
"vec_norm-->":vec_norm,
"vec_binorm-->":vec_binorm,
"line_direction-->":d}
OUT = my_dico
Cordially
christian.stan
Lines don’t have plane, so it’s not works correctly with ComputeDerivatives() (return a Zero Vector)
a solution with the crossproduct (with BasisZ vector)
import sys
import Autodesk.DesignScript.Geometry  as DS
st_pt = XYZ(2,2,0)
end_pt = XYZ(5,9,1)
line = Line.CreateBound(st_pt , end_pt)
vectorL = line.Direction
vectorN = vectorL.CrossProduct(XYZ.BasisZ)
OUT = line.ToProtoType(), vectorN.ToVector()
@christian.stan
I’ve run your script and I got this error!!??
Thanks.
hello, I have to read the small lines with a rested head, I think the 2nd script is more correct than the first, even if not adapted to the lines
import sys
St_pt= XYZ(1,1,1)
End_pt= XYZ(5,5,5)
line = Line.CreateBound(St_pt,End_pt)
a=line.ComputeDerivatives(0.0,True)
vec_tang=a.BasisX
vec_norm=a.BasisY
vec_binorm=a.BasisZ
d=line.Direction
OUT = my_dico,a.Origin
Cordially
christian.stan
@c.poupin
We can’t got a normal vector if the curve is straight??
st_pt = XYZ(2,2,0)
end_pt = XYZ(2,2,5)
OUT = vectorN
So how the normal vector is obtained in the case of straight rebar? (ex: column rebar)
Thanks.
it seems to me that as your direction vector is in fact your tangent vector as you make a cross product of vector Z and itself is carried by vector Z, they are therefore collinear this is how you demonstrate from my old memories of math, you have to select another XYZ.BasisX or Y will do I think, I’m testing…
edit:
Cordially
christian.stan
the Normal of a vertical line could be any vector based on the XY plane
@c.poupin
but how we can extract it from the curve itself if ths Cross Product give 0 ??
Thanks.
There isn’t a consistent normal for a line; as @c.poupin noted, it could be anything without a Z component, and the Tangent would be any vector perpendicular to that.
Gather the normal from the work plane which defined the element, it’s sketch, or the host.
I think that as dynamo provides one, it is possible via the api
looking at the dynamo nodes or maybe using them
edit:but it’s true that when you have a face it’s better to define a normal
Cordially
christian.stan
Yeah - the Dynamo geometry engine makes some assumptions about what the normal is; however that geometry library isn’t in the Revit API, and the assumed normal os often incorrect (in particular with vertical curves).
Line has a Direction property so:
St_pt = XYZ(2,2,0)
End_pt = XYZ(2,2,5)
direction = line.Direction.Normalize();
For a more general purpose use, i.e. any curve, do what’s being suggested above:
  1. Compute the derivatives.
  2. Get the BasisX of the returned transform.
Wouldn’t this be the tangent, not the normal?
Yep, I made the wrong assumption re the OP! @c.poupin is the solution in that case: @REDO10 you need to know your up-vector (or plane normal) to be able to compute a normal from a line.
1.- Create a plane: CreateByNormalAndOrigin(CurveDirection, Origin)
2.- Get the XVec property of the plane.
3.- Get the cross product: XVec.CrossProduct(CurveDirection)
Regards,
