Get Z vector from a curve - python
can anyone help me isolate the Z vector in this python script?
This outputs the element curve of in my case a duct.
If i can get the Z Vector or Z values of start and end points i should be able to isolate any vertical ducts.
#Import Revit Nodes
# Import RevitAPI
clr.AddReference("RevitAPI")
clr.AddReference ("DSCoreNodes")
import DSCore
from DSCore import *
elements = UnwrapElement(IN[0])
curves = list()
vertical = list()
spoint = list()
epoint = list()
for element in elements:
	loc = element.Location
	if loc.ToString() == 'Autodesk.Revit.DB.LocationCurve':
		curvepoints = (loc.Curve.GetEndPoint(0).ToPoint(),loc.Curve.GetEndPoint(1).ToPoint())
		curves.append(loc.Curve.ToProtoType())
OUT = curves
#OUT = vertical
any help would be much appreciated!
Thanks,
You can get a Z value of a point easily before you convert it to Dynamo geometry. Like so:
p = curve.GetEndPoint(0)
z = p.Z
However you can check verticality by using a cross product against a global Z vector:
isVertical = XYZ(0,0,1).CrossProduct(curve.GetEndPoint(1)-curve.GetEndPoint(0)).IsAlmostEqualTo(XYZ(0,0,0))
