Nodes disappear after save and reopen
Noticed that when i save and reopen the dynamo, node ‘List create’ and If (control flow) node is disappeared and have to be newly added again. Did anyone else faced this issue ? how to fix it any suggetion ?
List_create
@shahid.shaikh_C3D can you confirm which version of Civil 3D are you using? you need to click on the question mark and click on the “About”
@Paolo_Emilio_Serra1 its 13.2.890.0 civil 3d 2020
@shahid.shaikh_C3D thanks, this was an issue that happened with an early version of Civil 3D and Dynamo. I’d recommend you to update to 2020.4 and also update Dynamo for Civil 3D to 2.4.1
Ok thanks will do that and check.
@Paolo_Emilio_Serra1 Thanks update fixed the issue.
