Need to reopen Dynamo everytime for it to run
I have created my first Dynamo. The result is what I expected. Yepee!
But oddly I would need to close the user interface and then reopen it before running it if I already run once ealier.
I guess it is due to some setting in my software? Anyone with this issue at all?
What version of C3D are you using? Have you check that you have latest updates?
/P
Hi @KayTang ,
This has to do with element binding.
@ patrick.ericson,
I was using 2021. But I recently updated to 2024. Then everything suddenly work. So I guess it was the version problem.
Or with caching, if there are no changes to the nodes, they won’t update on a second run. It could be forced by removing the lace from the first node in the tree, run the graph and reconnect the first node.
