Hi Everyone,
I’m having trouble setting the lacing/levels for the Element.SetParameterByName node to work with multi-lists and sublists. List 1 and it’s sublists are correct, list 0 and it’s sublists are the issue (the lists circled below should be the same elements as in list 0 sublist 0). The screenshot below is the closest I got. Does anyone know if there is a solution for this issue? Thanks
