I found this script on an earlier post and modified it. Question is nothing happens when I run it. I have a couple bars that are QTY=14. It works when I change it to the Mark parameter
If you remove the IF statement do u get all the rebar, or still no values?
Also it says completed with warnings, but I don’t see warning. Can you share that info?
