If and elif condition returning 0
Hi!
I tried to write a simple python code for adding prefixes. Code below:
import sys
Param = [0]
output = []
# Place your code below this line
i=0
for i in Param:
	if Param[i] == "-3":
		output.append("Rebar Hook: -3")
	elif Param[i] == "-2":
		output.append("Rebar Hook: -2")
	elif Param[i] == "-1":
		ouput.append("Rebar Hook: -1")
	elif Param[i] == "1":
		output.append("Rebar Hook: 1")
	elif Param[i] == "2":
		output.append("Rebar Hook: 2")
	elif Param[i] == "3":
		output.append("Rebar Hook: 3")
	elif Param[i] == "8":
		output.append("Rebar Hook: 8")
	elif Param[i] == "9":
		output.append("Rebar Hook: 9")
		output.append(Param[i]);
OUT = output
The result is always returning as 0. Snip below
Any pointers would be nice!
Thanks!
It is because you are not looping the parameters correctly, an dyou have set i to always be 0 and you don’t increment it on each loop.
Params = IN[0] #what is the storage type of this? Number or string?
output = []
for Param in Params:
    if Param.AsString() == "-3": #or Param.AsInteger() == -3:
        output.Add("Rebar Hook: -3")
OUT = output
Your variable Param is a list containing a single integer, 0.
for i in Param:
In this case, i will be 0:
if Param[0] == "-3":
    # etc.
Param[0] equates to [0][0] or simply 0.
Therefore, 0 == "-3" evaluates to false as 0, the integer, is not a string. As Sean has noted, you probably meant to write Param = IN[0].
That being said, I would personally use a single conditional statement:
params = IN[0]
output = []
hooks = ['-3', '-2', '-1', '1', '2', '3', '8', '9']
for param in params:
    if param in hooks:
        output.append('Rebar Hook: ' + param)
        output.append(param)
OUT = output
I’m amazed at how the program literally takes what we give.
@SeanP thanks a lot for pointing out that major blunder.
@cgartland yes, i meant to write Param = IN[0].
Few questions:
  1. Is param short for parameter and python recognizes it?
  1. What does it mean if the script throws this error?
This came out from the line of script which i wrote initially.
Btw, your script works perfectly @cgartland. Thank you! :slight_smile:
In most cases, variables are just assigned by the user and can mean anything they want. Apart from the python built-in types and functions (int, str, float, etc.), Dynamo has two reserved variables: IN and OUT. Outside of the context of the Dynamo Python node, IN and OUT have no inherent meaning in Python. In the code above, I am assigning the first input IN[0] to a variable params. Then, I am using a for loop to access each item contained in the list:
# for each param in list params
Compare this to your original for loop:
# for each i in list [0]
for i in Param:
It is common to use i as a variable name, but this is just convention. However, it is most commonly used in this manner:
for i in range(len(params)):
    param = params[i]
This is because range() returns a sequence of integers which can then be used as indexes to access different items in a list. If we take the first 3 items of your list and break down your for loop, this is what’s happening:
Param = ['-2', '9', '-1']
for i in Param: # first i in Param is '-2'
    if Param['-2'] == '-3':
        etc.
A string cannot be used as an index, so Param['-2'] will raise an error.
Thanks a ton for the detailed explanation. I’m just starting out in python, so im trying to write simple codes in python, also in places where a conventional OOTB nodes would do the job.
I will keep the above points in mind when I write scripts in future. Thanks a lot again :smiley:
