Newopening method
I am trying to use the newopening method for wall in a python script block. I input wall elements , start point and end point of the rectangle. When I run it python messages that a “level is expected”. So actually I noticed the newopening for shaft is exactly same method. I do not know how to procede. Please anyone can suggest me?
PS. I am quite new to this world so i apologize for any stupid thing that I have done!
here the code
clr.AddReference(‘RevitAPI’)
openings = []
walls = UnwrapElement(IN[0])
points = IN[1]
for idx in range(0,len(walls)):
StartPoint = (points[idx][0])
EndPoint = (points[idx][2])
opening = doc.Create.NewOpening(walls[idx],StartPoint,EndPoint)
openings.append(opening)
OUT = openings
Hi Emanuele
Python is selecting the wrong overload of NewOpening. You need to give it a hint, something like:
	opening = doc.Create.NewOpening.Overloads.Functions[3](walls[idx],StartPoint,EndPoint)
I’m using the [3] index because this is the 4th overload listed in the Revit API Help. See Daren’s explanations for more:
Hi David,
Really thanks for you message!
Just another question, can you suggest me any book or whatever to study deeper python and also revit API?
Thank you so much David.it will be very useful.
